- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
A cross post from a email to a customer:
You can test the complete 81-87 2F ignition system on the workbench.
Supplies:
- A coil & ignitor assembly and a distributor assembly
- a source of 12VDC power. I use a gel cell battery from an old computer battery backup. A car battery or a 12V rechargable drill battery are also good sources.
- test lead wires w/ alligator clips
- clean sparkplug gapped at ~.040"
- known good coil or plug wire
- large vise grip or small c-clamp
Setup:
-remove cap & rotor from dissy.
-insert coil or plug wire into end of coil.
-insert sparkplug into end of coil wire.
-Clamp plug body to foot of coil w/ vise grip or small c-clamp, so that plug gap is visible.
Connections:
-plug ignitor lead into dissy.
-connect -12V lead to mounting foot of coil
-clear the area! connect 12V+ to coil + terminal. ignition is live now.
-spin dissy shaft by hand. spark should be visible & audible at plug.
-disconnect battery. watch out, coil will spark one last time when battery is disconnected.
HTH!
PS: can a mod stick this on the tech page?
Supplies:
Setup:
Connections:
HTH!
