My truck was running great, but I took it on a drive and it seemed to have lost all power between idle and boost. If you punch the accelerator it will do absolutely nothing for up to 5 seconds and then start to gain power. once its revved up in runs fine (maybe just a bit less power than usual). If I crack my injectors, this symptom goes away for a while, but starts to come back.
Presumably Ive got an air leak somewhere then right??
Is there any way to determine whether this happening between the pump and the injectors, in the pump itself, or somewhere between the gastank and the injector pump?
Fwiw, I replaced my fuel filter and every rubber fuel line in the engine compartment recently so I dont think its the lines there. My primer doesnt seem to work, but I was able to prime it with a transfer pump when i did that work.
Any thoughts on where to start here?
Lars
Lars
