I was starting to do a front brake job today and ran into an issue I can't get past.
When I removed the hub flange, lots of metal came falling out. I identified this metal as the lock ring with the bendable tabs. It completely fell apart.
The outer 54mm axle nut came out stuck to the back of the flange and seemed heat-welded there. I had to clamp the flange on a vice and hit the nut with a chisel to get it to come off.
And finally, the biggest issue, the inner axle nut will not budge. There is about 1/4" of play where I slide the rotor/hub back and forth, but I can not get the nut to budge. I tried a 20" breaker bar with the 54mm axle socket and could not get it to budge either way.
How would you proceed? Should I try heating it up or cutting it? I'm not sure if I could even get a dremel in there. Any ideas appreciated.
