Been wondering about how often one should change the pads on the emergency/parking brake, if at all. Nice to see that they put in a separate system but it looks like a pain to change the pads unless one has the whole thing apart already. Also IIRC not obvious if it's possible to check the thickness without needing to take things off.
Then, of course, if these are not used with a moving vehicle maybe they shouldn't wear at all if the system is adjusted properly, but the FSM lists some minimum thickness as if it were routine to change these things.
Sooo, anybody has any idea of a realistic time frame to change these things?
And is there a way to measure or eyeball the thickness without taking it all apart?
thanks
Eric
thanks
Eric
