Should I just replace this obvious little area or is there a more clever way to do this that I should know about? Also how do you deal with laying the new sheet metal over the tub support? Does it get tacked to it underneath the tub? I've cut along the support, but didn't finish as I used a sawzall and couldn't make tight cuts......probably will use a small cutting wheel on my 90 degree IR air grinder. Panel to the left is thicker than under the seat, and must be a replacement panel. I have preliminarily outlined the section to remove with some Neat-O looking dots...
I'm thinking of sandblasting the tub, priming it, and lining with linex or the like. Outside gets rattle can. I'm keeping this rig a loooooong time so patch these spots, blast away the surface rust and old paint, use a self etching primer that will get down into the seams, and prime it?
