How I fixed my temp gauge
I was always upset that my temp gauge was staying very low. Between the low mark and 1/4 of the full scale.
What I did?
Tryed the gauge with a short, it was working.
The fuel gauge was accurate. The needle is on top when the tank is full. Ok
I understood the regulator in the fuel gauge was sending the power , abaout 7volts, to both gauges.
i undestood the screww on the regulator was used to calibrate the power. In the factory I guess it was calibrated once and then glued.
To screw clockwise gave more power to gauges, more heat and more deflection of the needeles.
My problem is the temp,sender.
I checked it in my oven wit a ohmmeter it did not meet the specifications of the FSM . To 105 degrees it is 29 ohms when it should be 23 ohms . To 100 it is 32 when it should be 27.
If I turn the regulator screw, I will make my temp,gauge more accurate but the fuel gauge less accurate.
I understand the toyota engeneers who could have used one regulator on each gauge, but found an other solution. As the range of the temp sending unit is 67 ohms, from 90 to 23 ohms , and the range for the fuel gauge is 153 ohms , 170 to 17 ohms and they deflect the same, the temp,gauge is 2,5 more sensitive than the fuel gauge.
The change of deflection of the fuel gauge will be less important than the temp gauge.
Brilliant!!
It is more impotant to check the temp of the engine than to know how much is left in the tank, as you can solve the problem with refilling when the needle is on the 1/4 low. If your temp reading is faulse you can have major mechanical troubles.
So the engeneers spared one regulator.
i surfed in the 60 section and found a guy who made e regulator for the temp gauge. An electronic card, fitted to the back of the gauge...seemed too complicated for me.
So I bought a regulator dc to dc who Change the voltage 0 to 24 volts
i disassembled the temp gauge, then cut the copper track between the output of the regulator from the fuel gauge and the temp gauge, then connected my freshly bought external regulator to the temp gauge.
Then the calibration. At 100 degrees I have measured the sending unit at 32 ohms. I disconnected the sending unit and replaced it wit a potntiometer calibrated at 32 phms, then turned the screw on the regulator until the needle goes to the place I want. Et voila
The external regulator
The gauge calibrated at 100 degrees
Hope this help, this costed me 15 euros the regulator, 5 euros the shipping, 5 euros the potentioneter, hours to think to it, and I am happy..
a whole lot simpler than an Arduino with an algorithm...so, your converter; does it get full 12 (or 24) volts primary input from a fused source other than the fuel gauge? then the secondary calibrated output goes directly to the temp gauge input? does the output voltage creep at all with the alternator kicking on and off? Thanks!
The converter accept 28 volts input max. Output max is 3 volts less than input.
i used a fused source, that works with the key. Perhaps the radio line. no music in my 55.
It seems to me the regulator is stable, anyway the needle is a lslow respponse system.
have you tied your sender back in and taken it on a road test yet? Very good tech on this, BTW:cheers:
the Eurozone always has better electronics and fabricating sources than the US markets seem to have...they don't want us to be self reliant over here...
For sure I made a road test today. Too happy to have a reason to drive my piggie.
You can get this stuff through amaz.. I guess
Yep. Here we use km, euros, and temps in celcius. And ciivilized people drive LHD cars. I am a rara guy driving Rhd here...
