How do I replace outer flange studs on 94 FJZ80 Land Cruiser? Is there a special tool? (7 Viewers)
Baltimore, Maryland
Over the years I have had the knuckles rebuilt four times on my 94 80 series Land Cruiser to include the birfields… the last two times I did it myself in the driveway. However, I have never replaced the outer flange bolts (I think that’s what they’re called) and the cone washers and this time I discovered the threads are too destroyed to put the nuts back on. I tried to be careful when whacking the flange in order to pop out the cone washers but they have finally had it. I have purchased replacement cone washers and studs and they will be here in the next couple of days. My questions are: 1) is there a special tool to remove the old studs and install the replacements?; and 2) do I separate the flange hub from the brake rotor to remove the flange studs from the back of the hub? While I wait for advice…here is a personal note: I have had my 80 series since 1996 and I absolutely love it… it is literally a tank and I will keep it until I’m gone. I’m 64 now but rebuilding the knuckles is getting physically harder each time. As I’m wrenching on the various nuts and bolts… my body is telling me this will be the last time! We’ll see in 5 years!
I usually double nut method.
Where you tighten the nuts to themselves on the threads and use the nut on the inside to untreated the stud.
I hope that makes sense, if not a video can help.
If you use the double nut method (see video below): using a ratcheting box wrench help things move faster.
Or, if you want quick and easy you can use a stud remover (socket) and an impact wrench, zzzipp and they're out. If you don't have an impact wrench buy one, a compact impact driver makes life so much easier.
There are many brands so if you already have some cordless tools you can stick with the same system.
FWIW I've used the Milwaukee FUEL SURGE impact driver for everything up to 14mm (and some larger bolts), it's very compact and lightweight:
There are also many brands of stud removers (just don't buy one from chy nuh, IME they fall apart/fracture after light use):
Here's a link to a Koken set (Japan):
To install new studs you can use the double nut method or a stud installation socket or "stud setter" (individually or as a set):
IME this type works much better than trying to use the stud remover sockets mentioned above which tend to leave marks on the studs
You can also upgrade the hub studs to something a bit stronger made by ARP (less likely to strip out):
Here's a couple of sources:
How many miles between knuckle services? Do you use a brass drift on the studs when trying to loosen the cone washers?
No I didn’t. I thought I was being safe using a brass hammer but it still deformed the studs. Your other question… I’m not really sure, but I would guess about 15,000 miles. No serious off-roading but I would say rough conditions on unpaved roads with gullies and washouts. I’m hoping this repair will last a little longer since I’m not really doing that kind of driving any more. Thanks for the response/question.
I double nutted some studs on the rear axle of a 79 that needed an axle overhaul. The studs were trashed and didn't come out easy. Several were so difficult that the nuts got destroyed.
I bought a stud extractor made by ARES. Worked flawlessly. To install I use the double nut method. Spray the hole with brake cleaner and blow out with compressed air before threading in until it bottoms out.
If you've mushroomed the studs to the point you can't thread the studs on, you may be able to clean them up with a thread file or thread die.
Being that you already ordered replacements I’d get a stud remover and zip 'em out. Harbor freight stocks some that will work long enough for one job.
Pro tip: next time, loosen the nuts and thread them on so they just go on past flush with the end of the stud. Use a brass drift to hit the stud and dislodge the cone washers. Once loose you can spin the nuts off and remove the washers and cone washers. This accomplishes two things. It protects the threads from damage, and keeps the cone washers from flying into oblivion.
