NeverGiveUpYota
Dare me.
Does the service manual say to put sealer on them?Yea I do understand they are meant to move, but I would think rtv would break long before the metal
Service manuals dont say to do a lot of stuff I have done to carsDoes the service manual say to put sealer on them?
That’s my point.Service manuals dont say to do a lot of stuff I have done to cars
Ok cool so both theories have some truth. Never any problems having the rtv in those slip joints?You all have covered a lot of ground already but here's my 2 cents -
The rings and springs that I had when I started this thread were in a NOS manifold, never used until I installed it a couple years back. But those rings and springs had been sitting in there for all those years before I got it, doing nothing. So they were flat, and they leaked, hot or cold.
When I did the manifold AGAIN as part of a head replacement last fall, I replaced the rings and springs with new ones and was able to compare. The new ones sit proud and suggest that they will partially seal when cold, and expand to seal even more when hot.
I did use the Ultra Copper RTV this time around, but not actually ON the rings - I put it in the slip-joint type junction where the horn slides into the rest of the manifold.
No leaks there after a couple thousand miles... just some leaks in other places. It never ends!
Stuff that I have done with much successThat’s my point.
No probs at the slip joints, and from the little bit that I can see, the rtv is holding up better than I expected.Ok cool so both theories have some truth. Never any problems having the rtv in those slip joints?
That's what the machine shop did to mine.@OSS So are you saying remove the riser flapper, and plug the holes, no need for the block off plate? Thanks
