How cold did you take it to? How about minus 33 F
Website
www.go2moon.com
I was driving the LC200 (5.7L V8) the other night in the subzero temperatures of Interior Alaska, waiting for the northern lights to show up. The truck thermometer was registering minus 33 F, which was quite accurate in fact. See temp reading on right side of the picture.
Has anybody taken it to more frigid temperatures?
Burrrr....
Coldest I've ever driven my LC was +3F few days ago through the mountains in Utah.
I'm surprised the engine temp was normal! I'd expect it to be a few ticks lower.
How well did the heater work?
I was out snowboarding a few days ago when the temp was -9 with a wincdchill of -30, no heater to keep me warm. I drive at -20 temps a few days every winter.
No problem with the heater. Notice the driver side temp setting was "only" 75, which kept me plenty warm. I actually drove the LC at 40 F below zero many times and it was fine too.
wow!
I've always been fascinated by scenic views you guys get up there...Could you post any more pics of your LC in Alaska?
I live in the Middle East in a hot climate...we only get rain for a few hours in a year in the so called winter...summer is hot hot hot
It's surprising that Toyota/Lexus temperature is always normal, in your extreme cold climate and in our extreme hot climate like as high as 120F in June to August (if you open the window it's like an oven)
This is because the OEM Toyota temp gauge is designed to have a "dead" or "flat" spot in how it shows the operating temperature. Basically if the engine temp is within a certain range it will always show the same temp on the gauge, then when it gets outside of that range it moves very quickly towards the direction of either to hot or cold. It has been addressed in the 80 and 100 section, I think more exhaustively in the 80 section because it was more of an issue with the 80 overheating too quickly after the gauge started to move.
If really you want to know the actual engine temp you could hook up an aftermarket gauge, or do a modification to the OEM gauge to make it show the true temp without the dead spot.
ScanGauge!!!
I had a great picture at minus 41F, but I can't find it anymore. It's definitely a great vehicle, as are most Toyotas.
Can't quite match you Alaskans. -24 or so when I was in Wyoming last winter. Probably a lot colder on I15 at 80. Heated up fast and didn't cough on start up like my Duramax (though that didn't stop it being a great truck too)
I'm really going to have to find that picture! :D
I do have a silver LC up in Fairbanks. I don't think I've ever seen another 200 series in Alaska, but maybe I don't get out much. Are you down in Anchorage?
Well, I can't find my picture from last winter, but I didn't have to wait long for a cold day this winter. Here's the snapshot of my dashboard this morning at a brisk -40F (coincidentally, also -40C). It's a little disturbing the noises an engine will make during that first startup of the day when it's that cold outside. It's like fingernails on a chalkboard. :frown:
Do you guys use engine block heaters? Is it bad for your engine to start it up when it's that cold?
I never did when I lived in colder climes. I've never heard that it's bad or had any issues either. Some of diesel guys use block heaters if their truck will be sitting un-garaged for a few days or more. I just made sure to put the winter front on when I had my Duramax so the cab would heat up faster.
Most folks in my area run engine block, battery, oil pan, and transmission pan heaters during the winter. As Carl also mentioned, I put a winter grill cover on my Powerstroke. Still, the engines make some horrific noises when they start after sitting for awhile. Most cars just take it in stride, as long as you let the engines warm up before driving.
Other "cool" things that happen in the extreme (and sometimes not-so-extreme) cold:
1. Rubber door seals and plastic trim pieces get very hard and brittle in the cold, which increases breakage and makes it difficult to shut doors (I actually shattered the flimsy rubber gasket on my canopy door the other day).
2. Tires freeze overnight and you spend the first few miles each day driving with flat spot until the rubber warms up and becomes more pliable.
3. Batteries freeze...I actually started my car and drove to the gym one morning. My battery froze solid while the car was sitting outside for an hour or two (I learned the hard way I had a faulty battery heater).
4. Power steering and brake fluid become very viscous at about -30F...which makes both systems feel like old school manual steering and brakes.
5. Windshields will crack along the bottom if you run the defroster too hot or for too long, especially if you have a rock chip in the glass.
6. The moisture in air compressor lines can condense in your valve stems and freeze them open if you try to inflate your tires outside.
7. Moisture in the fuel lines can freeze and cause blockages or breaks in the fuel line...most people use fuel additives and keep their tanks full to reduce moisture in the tank.
8. It's highly recommended to wear gloves when working with metal tools and parts outside; otherwise, you can get contact frostbite when your bare skin touches the extremely cold metal.
Unfortunately, some of these are lessons learned from experience. :crybaby:
For Russia especially in Siberia temperature in-40C = -40F the normal phenomenon during the winter period, times reaches to-50C
Can the heaters run off of the battery? I've seen pictures of plug in stations around towns in Alaska. Are there outlets to let you plug in your heater extension cord in most places? Do you have one of these?
http://www.youtube.com/watch?v=AsPS3vz_y0Y
I guess it's a must when house hunting to find a heated garage up there.
