Time for a new horn? Or something else?
I also had this same problem. I went ahead and replaced the horn because I found a cheap deal on Amazon and haven't had an issue since. This was about 2 years ago now or I would recommend what I'm using. That Hella Trumpet I bet would work just fine. Hope it works out for you as easily as for me (and appears the others too)!Figured I will resurrect this thread first before posting another Horn thread.
My horn is also blowing the fuse. When I press the steering wheel I can hear the relay click. I can press it repeated and hear it click each time. If I hold it down for more than a moment it will blow the horn fuse.
Here is where it gets a bit odd. When I hit the alarm button the horn works fine.
steps taken so far:
I have swapped out the horn relay.
Tested horn button, confirmed relay is triggered.
I didn’t have much time to test further and my garage was freezing so I will revisit tomorrow. I did disconnect the (I believe low tone?) horn that has a single wire. I assume one has a positive in and positive out to second horn and the other just has a positive in and they are both chassis grounded via the mount? No change in behavior with the single horn connected other than the horn now sounding sad and wimpy.
Any thoughts?!
There's multiple touchpoints to the horn and possibly multiple computers based on my googling. I remember some potential in depth diagnostics that could be done to test something in the steering wheel ( i think was call the clockspring). But since the horns were easy to replace and I found the good deal, I tried the easiest fix first. Hope this works for you too!
