- Thread starter
- #21
Okay, now that I've read your other thread...
-Did you ever check/adjust the valves? With 18" of vacuum you are probably in pretty good shape but just asking.
-Have you ever checked or replaced the fuel filter? New OEM are still available from Toyota and it sounds like you have a reasonably decent dealer close by. If your fuel filter is clogged it may be starving your engine.
-How are your timing adjustment and vacuum lines to your distributor?
Matt (and all):
First, I have to admit with
that I have reported the wrong gears on my 40 - I said I have 3.73 - I was wrong - sorry!!
In speaking with Jim C, this morning, I rechecked the plate, on the firewall and what I read as K052 - what I have is K082, which is 4.11 gears - at least, that's what originally came with the truck.
So, that should mean that comparing my '78 FJ40, with H42 tranny and K082 axle to your '78 should be more of an apples-to-apples comparison
Jim also told me that he's sure the secondary is good - he rebuilt it and tested it - and that I definitely have a problem - probably a combination of problems, as well as commonly faced issues, resulting in fuel deprivation:
Jim suggested I get the new oem fuel pump, test both the input and output ports, install it, fill up with gas from an airport or marina and repeat the climb... after heat shielding the fuel lines. Onur Fed-Ex'ed the replacement pump this morning - it should be here tomorrow. I'm gonna wait for the new pump.
Re: your questions:
1. I adjusted the valves (hot) about 3 months ago - and had only driven about 50 miles, prior to this 700 mile trip.
2. Fuel filter (oem) was also new, about 4 months ago - and had only driven about 50 miles, prior to this 700 mile trip. Note: I pulled and replaced it after this trip and found nothing wrong with it.
3. Timing set at 7* BTDC, about 4 months ago. Note: I was reading , this morning, trying to find out if there is a more practical setting than the 7* that the FSM states.
4. Vacuum lines are all new - I replaced all hoses (underhood) while re-installing my carb, 2-3 weeks ago.
So, my plan...
a. Test and install the new fuel pump
b. Already replaced fuel filter
c. Re-check/adjust valves
d. Re-check/set timing
e. pull, clean and regap plugs - Note: plugs, rotor, dizzy cap, plug/coil wires, PCV are also about 4 months old. Oil is fresh, oil and air filter are new. Coolant ne, about 3 weeks ago.w
e. Install fuel line heat shield sleeves - Should be here in a few days
f. Fill up with airport gas - BTW: I have a habit of topping off my tank, in older vehicles (like my 40 and my 2002 Tundra) - I read, this morning that doing so can cause some sort of fuel delivery problem in an FJ40. I didn't fully understand it. But, will quit topping off my tank, regardless.
g. Try the same or similar climb and see what happens.
Common Issues:
Also, I'm sure the fact that Jim tuned my carb for 2400' and I was climbing at 7400' could also be construed to be another 'common issue'.a. outside temperature
b. climbing a hill means fuel pump trying to pump uphill
c. current gasoline becomes less and less efficient in our old 40s.
d. my gas tank was almost empty - I don't think I reported this - there was no shoulder to pull over, or I would have poured my jerry can contents into the tank.
e. new fuel pump could have actually been leaking, from the cross threaded 90* connector
Problems:b. climbing a hill means fuel pump trying to pump uphill
a. VERY hot under the hood.
b. exhaust headers.
c. fuel lines, above the headers, not shielded
d. potentially bad or leaking fuel pump
e. potentially plugged fuel filter
b. exhaust headers.
Re: your questions:
So, my plan...
My Dec 78 FJ40 with 32" tires and 3.70 gearing used to run between Vegas to Reno and Reno to Ely all the time. Never was I down to 45 mph on hills.
Thanks Mace!
Turns out my gears are 4.11
redface
- my 40 performed great on the trip - except when climbing - the steeper the climb, the larger the power loss.
But, couple that with the single instance of vapor lock, after cresting the climb out of Tonopah, and it certainly seems to be a heat-related fuel delivery problem that's resulting in fuel starvation.
So, I think I'll come out of my 'plan', above, with '44' searching out hills to climb
Thanks everyone!But, couple that with the single instance of vapor lock, after cresting the climb out of Tonopah, and it certainly seems to be a heat-related fuel delivery problem that's resulting in fuel starvation.
I'll report the results, when I have them.
