august '77 40 California spec with all smog equipment in place. PO let the belt break on the air pump and never fixed it. pump seized. In an effort to stay original and smogged, I've obtained a refurbished pump and attached a new belt. All systems are functioning on visual inspection.
First run out of the garage and I've got a new backfire on decel and on gear changes through the tailpipe.
Timing is good (arrow and BB line up perfectly).
currently running Aisan carb stamped august 1982....I have the original august 77 carb rebuilt and ready to go.
420 mmhg vac steady at the booster with no detectable leaks
Best i can tell, I have now introduced air into the exhaust system and 2 things are possible...
1) with the timing being good, i'm running too rich. Air, fuel,heat = kaboom out the tailpipe.
2) valve lash is off and i'm sending unburnt fuel out. or at the wrong time.
Other than rip the smog stuff off, where would one go from here?
hOOter
hOOter
