@TonyP is right, you want airflow under your solar panel if possible. Panels lose efficiency as they heat up. Your metal hood gets hot. Even a small airgap in this case isn't ideal, you really want a few inches at least. Roof rack mounting is better if you have the space.
Panel angle will make a difference in output as well. If they are mounted flat you lose 10-30% of output depending on time of year, location on the globe, etc.
Also shading any part of the panel will really hurt. Even a small amount of shade will drastically reduce output. So on your hood might be OK if the sun is directly above but if it's partially behind the truck and a part of the panel gets shaded by your roof, RTT, etc it'll seriously drop the output.
Panels are in my experience about 50% efficient. So a 100W panels will get you about 50W at peak. Maybe 60W if you're lucky. You'll get much less when the sun is low (~20W). I don't know how much power an ARB fridge draws over the course of the day, but you might be better off getting one or two flexible panels but NOT attaching to your vehicle and instead attaching and repositioning them when you park to camp then putting away when you drive.
Also keep in mind the force of wind doubles every 10 mph, so your panel needs to be mounted TIGHT or else it'll rip off. I have a friend who had a pair of flexible 100W solar panels on his trailer roof. They were taped down using Eternabond. If you've never used that stuff it's like duct tape and 3M VHB on steroids, and it makes a water tight seal. Still the airflow across the roof caused his panel to pop loose on the highway at 75 mph one trip, at which point the panel became a sail and broke away at the MC4 connectors. Not sure how it happened but we think some water got underneath which loosened the tape
Moral: I wouldn't try to mount a flexible panel to your vehicle with any sort of air gap under it. Just sayin'
