I could be wrong but to be honest I don't think you need that hockey puck spacer with the timbrens, if you remove them you'll get more up travel and articulation in the rear and will probably still hit the bump stops easily before rubbing the wheel well.
I'm running
toytec 2" bump stop spacers to drop my stock bumps down and I also have a clear marking on my axle from where they come in contact w/ the axle when fully flexed and I do not have any issues w/ the tire rubbing on the wheel well.
I'd say those bump drops make the stock bumps about as long as the timbrens without the puck spacer so you should be in better shape if you just lose that spacer rather than putting in longer springs, because if you sit level and like your current stance and spring rate, raising the rear with stiffer/longer spring will cause you to sit less level and more stink bug (rear higher than front) and potentially sacrifice ride quality. Removing the spacer will allow you to keep your current stance and spring rate but gain rear articulation, likely without any additional rubbing.
