Holley EFI Leaning Out / Drivability Issues
Spokane, WA
Just wanted to check in and see if someone can provide some insight into the Holley Sniper system here --
Over the last two mornings, I've had severe drivability issues with my Sniper EFI system. It starts with dying at idle coming off deceleration in gear, and eventually evolves into failing to maintain an idle due to excessively lean fuel trims (A/F ratio value on the handheld unit is ready 20-35%+, worse under load).
I figured I'd just throw a fuel filter at it while it was in the shop. 5 minutes in and out, and she was running good.
Got home, parked it, and woke up the next morning -- same thing. Choking / sputtering / dying. A/F values near 20-30% again.
I don't have the EFI dongle, so I can't do any of the techno-wizardry recommended online, but if someone could tell me if I'm on the right track here:
If I disable closed-loop fuel control via the hand-held display (assuming my best mixture / fuel map hasn't been corrupted by the above), would that isolate the wide-band HO2S as being at fault if the EFI system were then to run as normal?
I'm a bit leery of the sensor primarily due to the astronomical fuel trims, and the fact that the past few mornings have been colder than normal. So I'm suspecting possible thermal shock at cold-start may have wiped it out, but don't yet have the tools to verify it and condemn the sensor (EFI dongle is in the mail).
Appreciate any advice.
Got back to the house. Tried firing it up - fuel is stuck at 35.6% at all times... seems like a hard fuel fault rather than input sensor issue?
Disabled Closed Loop operation, no change... tells me the wideband HO2S is probably not to blame -
Inspected the barrels of the EFI unit and found the passenger-side was not receiving fuel during key-on cranking.
Removed the front cover of the Sniper EFI unit and found the passenger-side injector connector partially unseated. Unfortunately Holley seems to have found the cheapest zero-retention connectors for these... so zip ties had to do the job. NOT thrilled about seeing poor build quality like this.
Fired it up and still zero fuel from passenger side injector.
Seeing as how I can't get a noid light set in here to verify injector pulse / signal, how does one go about diagnosing this? Just measure the resistance of the injectors? Swap injectors to see if the issue follows the injector? Disconnect fuel pump source voltage wire and crank to check injector pulse? Or is the Holley software smart enough to shut down injector pulse if it doesn't see fuel pressure?
Interested in seeing if I can source any aftermarket injectors or higher-quality connectors for these as well.
what are the odds your fuel system is garbage ?
I would hope very slim. I've got new hard and soft lines from the tank to the EFI unit. I'm using two brand-new Wix 33003 filters before and after the pump, and have verified good fuel pressure (59psi on my OTC gauge). No excessive resistance between fuel pump B+ to battery and ground post to negative terminal.
Guessing you actually meant 33033 as a 33003 is a lawnmower filter... either way 33033 is only a 20 micron filter so not really rated for EFI. (Holley states a minimum of 10 micron rating for EFI fuel filters).
I would swap the injectors and see if the issue follows. I would bet you have a bad/clogged injector
Definitely meant 33033 - I swear I'm not dyslexic. As for not meeting Holley's ratings, I just matched the part number that came in their kit - I'll double check and make sure I'm not mistaken.
Both injectors tested good, at 12.0ohms. Swapped the injectors, problem didn't move.
Took the fuel pump relay out to disable fuel and cranked it over, and there was no pulse at the injector connector...
Found out that the cheap connectors they use on the Snipers have 0 retention between the wire and terminal, so it just backed itself out and was making intermittent contact. Ran to the parts store to get an EV6 connector, spliced it in, and we're firing on all cylinders now.
S824 is the part number if anyone else ends up running into the same issue.
Appreciate the help.
Glad you were able to fix it.
As for the filters, double check the Holley instructions, the one you have is what they recommend for the pre-pump filter only.
Hello everyone, going to post this here as leaning out & drivability seem to be part of my issue. I have an 87 FJ60, 260,000 miles, de-smogged, DUI HEI & Holley Sniper that I would call my daily driver. I’ve been running the Sniper for several years now and it’s been pretty flawless. The other night on my drive home on the highway the engine began to stumble in the 1200-1800rpm range, no power, and the AFR went very lean. I managed to nurse the truck home but it died a few time and would not idle below 2000 rpm. I began what turned into a multi day effort to figure out what went wrong and here is where it sits…
- HEI distributor advance was seized.
- #6 spark plug wire was bad
After fixing these issues I still could not get the truck to idle without turning the closed loop comp on the Sniper up to 200%. It also felt like the engine was misfiring occasionally. I have done the following since:
- Timing
- Valve clearance (Also confirmed the rockers are in fact pushing the valves and that they return as well)
- All new plug wires
- All new spark plugs
- Confirmed spark on all 6 plugs
- Fuel pressure is constant and correct. I have also confirmed it is in fact pumping fuel.
- Checked the IAC
- Checked the injector connections on the Sniper
- Checked for vacuum leaks. Vacuum gauge reads a steady 19” Hg at idle with the loop comp around 50%
- New o2 Sensor
- New wizard ran on the Sniper
- Disconnected and plugged PCV while I wait for the fixed one listed in the above posts
I also ran a can of Seafoam spray through the Sniper hoping it might loosen up any valve issues.
After all this it seemed to be running a bit better but still struggling and occasionally missing. I ended up completely swapping the distributor for a brand new one and that has resolved the misfire issue. I double checked the timing with the new unit, played with a few different adjustments but settled on 9 degrees as that seemed to hold the best vacuum. I still have the loop comp at 100% as it wont idle otherwise. I had to adjust the throttle plate screw in a bit to get the IAC to hold below 10. I have noticed that once the truck is warmed up it will idle at 750rpm, 30% comp, and hold a steady 12.0 AFR. If I give accelerator input it will stumble slightly, go lean (18-25 AFR) for a moment and then eventually recover above 1500ish RPM. Above 1500 rpm it smooths back out up to 3000 rpm.
A lot of info I know but hopefully I’ve done a reasonable diagnosis to try and get some input back, any ideas would be greatly appreciated. I‘m guessing my engine is finally failing, a combination of valve leakage/sticking, and worn rings. My compression numbers were pretty terrible (140, 150, 135, 125, 130, 135). Back in 2020 they were all 150+ with the exception of #4 which was 120 dry and 150 wet. I did not do any of them wet yet…. Trying to decide if I should pull the Sniper and the HEI and go back to a Carb/Toyota Dizzy to see what happens or just say enough, save the money and go for a rebuild? Out here in Brooklyn there aren’t any shops I would really trust to do the work so I want to make the best attempt at diagnosis before I ship it off to another state, also most shops are many months out of being able to work on it anyway.
Thanks in advance for any advice and input!
