Hello maybe this is not the right place to ask this but i am getting a little desperate
Hello i am currently rebuilding 2 HJ61 FullFloater axles whith original toyota cable lockers.One problem is that the bearings from the carrier seem to be different from all the other toyota axles,they are also shim adjusted instead of nut adjusted.The old bearings that came out of the axles are Koyo but the part number on the inner ring is 32012JR-N while the outer part says 32012J/1B-N .I drove all over the country here and every store sells bearings with the same outer and inner diameter but the whidt is different
on shopkeeper even proposed to make from 3 different bearings one that looks similar
So does anybody has more info on this or knows where to order them(Toyota in Panama didn't have them ,delivery time aprox 6weeks:whoops
so anywhere in the states or europe where they are available please let me know,so i can mount them under my BJ
If anybody has the numbers from SKF or other quality bearings every info is welcome
