hj 60
JT1W0HJ6000960839
- Joined
- Aug 1, 2012
- Threads
- 11
- Messages
- 2,695
- Location
- Netherlands Hengevelde
- Website
- www.tapatalk.com
If you keep the car and budget is there buy quality like victron, used a lot in mobile homes: (in europe)
not that jiblejable language: Victron Energy
One model (Orion-Tr) has an extra 12v switched on/off (called isolated) to prevent battery drain but I suppose they have a drain protection.
And it can charge an extra 12v battery which isn't bad to use as a spare (eventually one battery will fail and starting becomes, interesting, so then I used a 60 Amp spare for a few weeks and it worked (charged, no fire, no explosion, no egg overcharging smell, no liquid spill) without any problem in combination with a 100Amp.
Chinese brand might be ok if you try to find reviews, some are sand in a box and others seem to be good.
Also a battery equalizer seems good practice but they are pretty expensive, like mentioned by other user (sved?) : Used Vanner Vann-Guard 70-100M Equalizer 100Amp
use search is a stupid comment but the truth is that this whole forum could be locked as everything is mentioned and done
DC-DC Omvormers - Victron Energy
De DC-DC omvormers van Victron Energy komen van pas als u geen geschikt voltage apparaat hebt en zorgen ervoor dat spanning wordt omgezet.
www.victronenergy.nl
Running 12 volts off my 24 volt system.
So what is the deal with running high amperage 12 volt access off a single battery in a 24 volt system. Does it wreck the alternator? Does it wreck the batteries that are under warranty, so badly that I can take them back and get new ones all the time? Thanks, E. Rockefeller.
forum.ih8mud.com
Search results for query: Vanner
forum.ih8mud.com
