Hello everyone!
I'm having troubles with my 86 HJ60.
I pulled the injectors to inspect the nozzles and to check if they were leaking at all. After testing all of them on an injector tester I installed them all back in and torqued them all to spec. After bleeding the injectors it fired up no problem, and for the whole day after that it would start up with no issue. Fast forward to the next morning and she wouldn't start, I had to crack the fuel lines and bleed them at the injectors. Once fuel started spurting out I tightened them all and once again it would start with no issue. The next morning it did the same thing and I had to crack the lines.
Anyone have any idea where to look? It seems to be pulling air in from somewhere inbetween the injectors and the pump but there are no leaks that I can see.
Thanks everyone.
Thanks everyone.
