HJ47 welcome here?
For an answer to your question Radd cruisers, take a look at pg. 37, post #1090, picture #3. The new Toyota bolts for fixing the retainer come with some kind of green threadlocker on the threads.
I either use loctite on certain bolts where it is called for, or a dab of grease, or, more often a drop of 90 wt. oil on all others. I learned from my younger days as a bicycle mechanic the practice of lubing bolts before assembly.
Someone recently told me that its better to use oil instead of grease on threads because the oil converts more quickly to a film that doesn't attract dirt. Anyone out there know definitively about such arcane matters?
and wow - hello page 41! I think I'm in the final page or two of this build folks. thanks all who read this for hanging in there through all the stages. :beer:
update...
the running boards have a coat of bed liner on them, Next will be some grip tex, tinted to match the rest.
I got the two niggling areas without enough paint on them taken care of today. The cab is done paint. In fact, I am down to five parts left to paint: doors, hood, roof and bezel. The doors are pretty much ready to paint, and the rest will need some attention. I'm hoping to get a set hung up for painting by tomorrow afternoon.
The fuel sender cover, along with the rubber gasket under it, are no longer available from Toyota and fairly hard to find in decent shape. The one that came with my truck was rusted into a version of swiss cheese, and it took me a few months of looking and inquiring to dig up a solid replacement - also coming from Australia. The cover is entombed in epoxy paint now, so it should hand around a whole longer.
I can't remember if there were rubber strips around the tank straps or not. I don't have any at the very least. For some reason the high side tank strap won't completely become taut when the bracket connection is done up all the way. I'll try and figure this out later.
Anyway, the crafty fuel separator has made and appearance on the scene at long last. Note the lone unit that attaches to the separator tank with what I presume to be some sort of check valve in it.
The cad plated metal union at the cab wall where the rubber pipes connect has the one loner pipe on it, especially obvious when viewed from the cab underside. Three of the tubes go to the tank from the union. The other one, on the far left as viewed in the first picture, connects to the check valve line. There is no 4th connection on the tank, so I guess this lone one is the end of the line and the tube just dumps out under the cab? That might explain what he welded-on fixing strap on the underside of the cab floor (visible in the first picture) is for: it secures the loose end of the rubber line. (?) Someone please enlighten me.
Then there is the fuel line itself, which has to cross over from it's exit at the tank to the other side of the chassis. I need to buy a little more line it seems. Again, i wonder if the straps welded to the underside of the cab floor are used to carry the fuel line? I tried the line in the straps, but they seem to pinch the tube when held in the clasped position. I definitely don't want any restrictions to the fuel line if i can help it.
