HJ47 Fuse box upgrade (1 Viewer)
Qld, Australia
Recently purchased a HJ47 to add to the fleet and been going over it and wanted to replace the bastardised fuse box.
Ordered a Narva 12 way blade fuse box which fits great.
The issue I’m having is the original had 3 feeds constant power, acc and On with ignition. Where the narva only has 2 feeds.
I have wired constant power to one and wired acc and On together but get the glow coming on now at acc key position.
Was hoping to make the fuse box take 3 inputs but might damage it pulling it apart.
Not sure what to do with the acc input?
Qld, Australia
Been in contact with narva technical support and they are looking into how i can remove the input bus bar and make a third input.
Qld, Australia
The response was you can make it a 3 input but unsure on how to remove the bus bar. So here goes nothing.
Soldered in another wire, but should have made the bridge 3 and 3.
Had to get a bit rough on the removal as it was an unknown but the fuse box reassembled feels solid.
