HI fellas,
I need to remove my Front shaft due to slop, but cant figure out the best way to remove the Transfer case end due to the Transfer X member being in the way and limiting access to get spanners on or decent tooling to get the stubborn bolts off.
whats the best way to attack this without dropping the Transfer case X member?
also whats the advantage of the Carden Joint over not having one, about $500 for complete front shaft but is without the carden joint.. im not sure if the slop is from the Carden ball joint or the uni joint (spider), i was going to replace Uni joints but now im thinking of just buying a whole new shaft without the carden joint
Thanks in advanced
Thanks in advanced
