Tried searching around for similar problems on here and couldn't find the exact case. Sorry if this is a long explanation.
Essentially, everything sounds and feels fine until I get into high gear on the highway/50-55mph, but the tach shows a much higher rpm than normal. Usually when I'm hitting 75mph it shows 2200, but is now pushing 3k, and 60mph is 2200. This will last maybe about 15min, and then the needle will start to flicker, and then fully drop back down to normal. If I get down below 50 on the same drive, and then push back up it starts the process all over again.
Loss of power isn't noticeable until going up a hill or the on-ramp. Not getting any codes either. Spark plugs/Transmission/dist? If it helps, I can try and film what the cluster shows.
With the shops all busy and hearing similar problems somewhat similar to mine are harder to diagnose, any and all help is appreciated! I've got a 22 hour drive coming up in 2 weeks from GA to ND, so if anything just hoping nothing in this means my 80 will blow up
'95 1fz-fe. Stock height and tires.
