So I read all the threads about sunroof leaks. All my drains are now draining. It was hard to locate the p-s drain outlet in the front b/c of that heat shield but I used the zip tie technique-thanks for that pearl. I lubed and then removed a petroleum based ointment on the weather strippings. Anyhow the drains gulp down water easily.
Question: Took a test run at the car wash-one of those automated ones at the gas station. Initially on the first rinse with the power washer, water beads formed immediately-a quick wipe and on other passes with the high pressure wash no other moisture. Is this normal with high pressure wash. Is it fixed. What is your experience? I am tempted to get another car wash to see what happens.
