High-mounted stop lamp from 80-series
Southern Colorado
Found an FZJ-80 stop light (center mounted) in a junkyard. Fits a 60 series about 98% perfectly. I ran a wire up from the left taillight, tapped into the trailer converter 'stop' wire (so it won't blink with turn signals) and ran the wire out through the D pillar vent and along the hatch opening. I soldered it to the leads from the 80-series light quick disconnect.
The light set consists of 3 pieces - a steel bar that was bolted to the 80-series hatch, which I attached with double-sided 3M foam trim tape. I then bolted the light itself to the plate and snapped on the black light cover.
Works great, super bright, OEM appearance, and there's no light splash-back at night in the rear view mirror.
I'm hoping this catches the attention of some latte-swilling, texting dolt behind me before he plows into me. Will also be helpful when trailer brake lights get flaky.
Steve
So the light is held in place by trim tape?
Yes. I could drill the upper hatch and install screws (as was done on the 80 series), but I figured that a foot of 3M trim tape would offer enough 'stick'. If it falls off next summer on a hot day, I will reattach with screws.
Primarily, I wasn't sure it would look/work as well as I wanted, so drilling was my last choice.
Holding rock solid - I'm always happy when the 3rd brake light is not dangling from the wire in my rear view mirror. What I really like is that there is no light leakage at night, so when you're in a dark area with your foot on the brake, you don't see a glow in the back of the truck. It truly looks/works like OEM. I also have not been rear ended yet ;-)
