Sorry this isn’t 2f but it is installed in a FJ40
Had an oil leak on the china wall so torn everything down to reseal. After letting it sit 5 days, I decided to try to start it and see if it would still run. It immediately ran up to 2800 rpm. I desperately tried to shut it down quickly. Thinking I didn’t hook up the throttle springs, I checked to throttle body…nope, springs hooked up and butterfly valves were shut. Tried it one more time and repeated the same start. Btw, it hasn’t been starting very strong but this was very strong.
Now for the details:
It’s a sbc, 383 stroker.
I removed the EFI, Holley sniper along with supply and return fuel lines. Removed the dizzy marking cap location but didn’t mark pointer. I believe I got it back to the direction looking down at the oil pump. Unplugged all EFI connections. Drained coolant and removed hosed. Cleaned and scraped all gaskets, installed new gaskets and rtv’d the china walls. Installed and torqued intake manifold. I also changed the EFI gasket from paper thin to 1/4 inch thick Holley gasket.
Of course I believe this has to do with timing but I can’t imagine how I could get to 2800 rpm with zero throttle.
Any ideas?
Any ideas?
