HID Cruiser/LX low beam bulb options
bloc
Central Texas
Hello all,
Recently bought a new (used) daily and it needing a new HID bulb caused me to revisit options in the upgraded HID bulb world.
For starters we use a D4S bulb in the 13-15 Cruiser, and I'd assume the LX570 is the same.
I've been a happy user for a couple years of the Philips 42402XV2C1 X-TremeVision Gen 2 bulbs which claim 150% normal light output. These things are noticeably brighter and get great reviews and on testing show solid improvement over standard D4S bulbs in light output but pretty expensive at around $200 for the pair. Also driving in heavy snow conditions on a recent ski trip I realized the slightly cooler color temp of roughly 4800K may have contributed to some glare issues with all that snow. While nothing will completely reduce the fatigue of driving through a wall of white, my understanding is a warmer color temp will reduce glare significantly and make it less fatiguing. This is the primary reason for many OEM's ~4200K color temp on factory bulbs, despite how visually appealing the cooler temps are.
With a little digging I realized Osram has a bulb called the NightBreaker Laser XENARC that claims 200% light output, and it turns out is a bit warmer at an OEM-like 4200-4300K. This should help a bit in fog and snow. Plus the pair is about $140 for our D4S application.. only $90 for my other car. Testing appears to show they do in fact produce more light than the Philips bulbs.. some tests do show a slightly warmer light color.
Has anyone used these? Or have other D4S bulb options that should be considered?
Am I wrong on the strategy for warmer temps (to a point) for better visibility in inclement conditions? I'm aware cooler temps get closer to the wavelengths of sunlight and can reduce fatigue in other driving conditions.
Note that I am not going for appearance.. I value performance over aesthetics. I'm unlikely to remove the philips unless something is convincingly better. I did order the Osrams for the daily driver though, and will report with my thoughts on that application.
I don't have much knowledge on specific HID bulbs, but I think 4500K give or take is right about the sweet spot for low beams. Some good yellow fogs really do make a difference in snow, especially if it's enough that you're driving slower anyway.
Good point about the fogs, I have Nokya hyper yellow H16s in that location and they did seem to help a lot. If it were possible to switch the primary lighting to a yellow color... that would have been great. But no really good way I know of to do that short of installing yellow driving lights..
Any update on this? I need new low beam bulbs now on my ‘15
I’m really happy with the osram nightbreakers in my DD but it’s hard to compare to the Phillips bulbs directly, with the very different beam heights.
I will say my concerns that the light color was too warm were unfounded. They look great, and not yellow at all.
