Specifically regarding KDSS:
Can someone give a run down of what I need to do? As far as I understand, while on level ground, I need to turn the two screws on the valve 3 times each. Am I then able to raise the truck as needed?
Once everything is installed, put the truck back down on level ground and tighten the screws back? How can I ensure I won't end up with any KDSS lean?
Thanks
Thanks
