Windshield 5611-60220. Delivered, does not fit.
I got 56111-60220 for my HZJ77 and it fit just fine.
Make sure you get the right rubber gasket for it. If you don't want the chrome trim installed back on it, then 56121-60120 is that part you want.
It was cheaper for me (that is also including the shipping cost) to get a new windshield from partsouq which also came without any damage at my front doorstep. They packaged it very well.
Prior to that, I had ordered one from a local dealer and it was a PITA because it was broken on one corner. If you go the local dealer route, be sure you check it over very well before you leave with it!
The delivered windshield was wrong and for a 60 series from 1985-1987, looks like there are only a couple 70 windshield available in the US and a bunch stuck on a boat off SoCal. But the right one should be coming.
Glass, Back Door
- 68131-60320
*TEM,T=3.5,RH,*TEM,T=3.5
- 68131-60330
- *EHTT,T=3.5,RH,*EHTT,T=3.5
- 68132-60150
- *TT,T=3.5,LH,*TT,T=3.5
- 68132-60160
*EHTT,T=3.5,LH,*EHTT,T=3.5
TEM,T=3.5 = Tempered 3.5mm
EHTT,T = 3.5 = Electrically heated tinted tempered glass, 3.5mm
TT = Tinted tempered
RH = rusty hut or might be Right Hand.
Absolutely right!Just don't even bother giving the "parts professional" at your local dealer anything other than direct part numbers. No VIN, year or anything else.
The North American Spec glass is often green tint where JDM is Bronze. Pretty sure I have some JDM rear door glass out of HZJ7 and BJ74s that I’ve parted.Windshield is on its way from local dealer . 5611-60220,1985-1987 BJ70 Canadian Domestic Market.
Toyota also has the back windows for he 1985-1987 CDM, BJ70. Is there any reason the back windows would be different than a 1991 hzj77? I had thought all the early 70 series back doors were the same and therefore the windows too.
That's good to know, I didn't even notice any tint in the JDM glass of my 77.The North American Spec glass is often green tint where JDM is Bronze. Pretty sure I have some JDM rear door glass out of HZJ7 and BJ74s that I’ve parted.
