1 dots on inside, 2 dots on outside, all in a straight line
Daughter's birthday over, I did some checking after work. Everything on the timing was inline. I put balancer at -0-, took off dizzy, rotor was pointing down. Took off valve cover, cams weren't aligned, so I rotated crank 360 right back to -0-, and cams were perfect--single dots meshed together and double dots outside, and all dots in a perfect line. Upper timing gear dot was right at 12 o'clock. Dizzy rotor was now right at #1.
Are these stretch bolts? If they are, are they intended to use one time only?
-Eddie
I usually clean the bolts, then oil them, blow with air, to get excess off. then set to one side until I am ready for them...
Hmm, hmm, hmm. The engine never really got hot in terms of activating the heat activated plasticky stuff that helps adhere. But. There were likely places that very hot gases were blowing past it if indeed the head was loose. So based on that assumption the gasket has been heated here and there to possibly cause the one-time-use adhesion stuff to activate.
DougM
Kevin,
The gasket sticks firmly to both surfaces, to the point you need a razor to remove the remains of the plastic film. It was interesting to note when I had to pull the head on the 97 back off after a week to note that in some spots the plastic had adhered fully and in others it came off with gentle pulling. I'm not 100% certain this is literally what they designed it to do, just noting that the tacky feel seems intended for adhesion and to handle minor surface imperfections. Interesting.
My head bolts were used twice after their initial installation at the factory for a total of three times. Just to be sure, I paid to have them measured by a machinist and they were all well within spec for reuse. So I'd imagine yours to be the same especially since it appears they weren't really properly torqued. There's a spec in the FSM showing how to measure and where.
DougM
DougM
scale in short order
