My 80 pulls right and has done so for quiet a while. I have read tons of threads and I think I have tried everything that has been discussed.
I will list what I have done and hopefully some new ideas will come about.
- Rotated tires - no change
- inspected and repacked wheel bearings - no change
- adjusted e-brake - no change
- installed 4 remanufactured calipers and soft lines from C-dan - much better braking, still pulling
- checked front end using Landtank guidelines - no issues found
- adjusted e-brake again - no change
- put straight edge to tie and relay rods - look straight
- checked alignment - all within spec, caster at 2.6 deg both sides
Little more info; truck pulled prior to lift with old tires, and pulls with lift and toyos, castor is corrected via blue FOR bushings installed using landtank templates.
If I put the steering wheel straight the truck will change lanes in about 2 seconds going about 40 mph. If I make the truck go straight and let go of the steering wheel it will pull right. It will do this in any lane so I don't think it is the crown in the road.
I have tried many things so I am sure I missed something. If you guys can think of something else I could try please post.
TIA.
TIA.
