orangefj45
Supporting Vendor
wheel studs are pressed in and should NOT be welded on!
a bent rear axle shaft can and will cause a vibration, but you'd see the tire and rim wobble.
a bent front axle shaft will not cause a vibration unless you're in 4wd.
if the u-bolts are new, then make sure you re-torque them. they have a tenancy to loosen up / stretch especially when new so i usually re-tighten tem after one day, one week and one month.
