My brother has a 1989 FJ62 that he laid on its right side - slow motion, killed the engine right away. After getting it righted and letting fluids settle... it started up and runs/drives, but idles rough as h*ll. Intake vacuum is only 10psi. I have also been having trouble with my '76FJ40 TBI so I built a simple smoke injection system to look for vacuum leaks (I'll have to get some pics and write that up for the forum). Anyway, with ~2psi of smoke being injected into the intake, there was smoke coming out of the EGR modulator. Does this sound right? Should it be closed while the vehicle is not running? I know that this is pressurizing the system rather than establishing a vacuum so the valve may be opening due to the pressure.
I did not see smoke anywhere else, except out the end of the breather where it was backing through the air filter.
TIA for any help you can provide.
