Hi guys, I’ve been searching here trying to find a solution to this strange problem.
I swapped the stereo and now the HVAC controls have gone dead - the fan does not come on at all no matter what buttons I push and the “AUTO” button will not light up. The buttons all “click” when pressed except for the AUTO button. It will not “click”.
Truck otherwise is running normally.
I’ve removed the HVAC panel a couple of times to see if the cables are all correctly plugged in. They appear to be.
I also checked that the toggle on the back is set to auto. It was set to “M” so I moved it to “A”, assuming that I must have moved it to M by accident during the stereo install.
The temp sensor appears to be connected.
I also removed and visually checked each of the spade fuses in the left knee fuse panel and the engine bay fuse panel on the drivers side.
Could this all be related to some relay or the fusible link? I see that mentioned in other threads. How can I tell if the fusible link has gone bad? Is there a visual tell?
On a related note, the stereo works great. LOL
