workingdog
GOLD Star
Installing champion 4 core radiator. Boy, is it thick - and tall. Putting it in the way the old radiator (not stock) was installed, the hood is hitting the radiator cap. However, it can go lower without modification, the radiator is very close to the support. Is there a standard modification that needs to be done so it will sit low enough? Champion said that they were aware people were modifying them to fit, but weren't exactly sure what they were doing. Grind out the radiator support so that it can be bolted lower?
What are people using as bushings between the support mounts and the support? Mine were disintegrating, so I used 1/4" body mounts I had, but clearly those are going to have to go.
