Help, CDL stuck, cannot undo
Discussion in '80-Series Tech' started by floydturbo, Jul 1, 2005.
  1. floydturbo
    floydturbo
    53
    Jun 17, 2005
    I installed the CDL switch this week and had some problems with the actuator. I could get the motor to open or close when I grounded the relay so as to give power to the actuator. After driving to work today, I parked the car and tried the CDL switch for fun, hey it works!!!!!
    On the way home, I tried it at a stoplight, and the CDL is stuck on. I can tell postively since the light is on and the front wheels scrub when turning.
    Anything other than removing the actutor??????
  2. PHAEDRUS
    PHAEDRUS
    2,040
    Media:
    1
    8
    Mar 31, 2003
    You can try to jump the wires to the motor itself but you run the risk of frying the motor. try going to some gravel and running back and forth with mild turns.
    that should clear it up.
  3. Rich
    Rich
    1,805
    6
    Jun 16, 2003
    I've never tried, but if the center diff lock bound due to windup, which is probably the case, then I would expect that shifting the transfer case into nuetral should unbind the drivetrain and allow the center diff to unlock.
  4. Aussie cruiser
    Aussie cruiser
    469
    Dec 20, 2004
    Brisbane Australia
    If it is just a case of windup this is usually fixed by reversing a few metres.
    I use mine to reverse my trailer up a steep driveway in low range and after the tight turn I usually have a case of windup. The reverse up the road afterwards allways fixes it. MAybe a sticky relay or a stuffed shift motor Test ing relay and motor should give you some idea.
  5. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    679
    Dec 13, 2002
    Knee deep in hookers and gin
    I would bet the actuator is stuck. I sure would't be jumping wires. You could fry the ECM really fast.
    Pull the bolts on the actuator and take it out and clean it.
  6. Gold Finger
    Gold Finger
    416
    Sep 28, 2004
    West Wales UK
    As Rich has said wind up may be binding the CDL, it is good practice to lock and unlock on a loose surface to help prevent this but we all forget sometimes to do it quick enough, especially if one is jawing at the time, I have found that reversing will unlock a stubborn CDL almost immediately. The alternate thing to do is weave about to create a differential speed in the axles and drive shafts which may take some pressure off the dogs.
