The PO installed cheap Belden plug wires. I'm at 116k and decided to do the plugs, wires, cap and rotor. The plugs, cap, and rotor appear to be original, but someone threw these on at some point. The long black plastic tubes that stick down into the head were all dried out and crumbling. I was able to get four of them out almost completely intact with the rubber boots, then picked out the crumbled pieces. Number one, unfortunately, lost the rubber tip. It took me a very long time to hook it and peel it free from the plug with a coat hanger.
My major problem is that number six snapped right in the middle along with the wire. There is just enough of it sticking out that I can barely touch the broken end with the tip of my longest finger. I can't find a needle nose long enough to fit down in there, and I can't get a coat hanger to pass the platic tube to hook the rubber boot from underneath. I also tried to drive a lag screw directly into the center to hook and pull it out, but the plastic crumbles and I just can't get a grip.
Any advice on this one I'd really appreciate. I thought this would be quick and painless. I've never had a problem like this, and I've done many plug changes. As luck would have it, my wife is out of town. I'm stranded right now, unless I drive on five cylinders... Any advice would be greatly appreciated. Please beware of these wires!!
