I found chocolate milk on the dipstick two months ago. I let it sit until time was available. Empied the oil pan today and found large amounts of antifreeze and chocolate milkshake oil. Oh poo. I thought the head gasket was blown (maybe that's all). I torn the head off and found no visiable trouble the gasket was not showning any tell tale signs of seeping. No I did not do a compression test. opps... My valve cover is coated in a waxy-honey like goo. It looks pretty bad really, I'm hoping the block is not cracked.
Questions: the gasket was covering two h2o jackets between #2 and 3 and #4 and 5 cylinder. Is that the proper fitting gasket? I have toyota part # 11115-61010 gasket is this the right one?
The engine had heating issues since it was dropped in (used 2F from a 1979, desmogged) and I've replaced most all typicals, radiator, thermostat, sending unit etc etc. This helped but it never seemed to drop below 190-210. I figured I was dealing with a cracked head, bad gasket etc and planned on a change of head. I've got a freshly done 2F head, 3angle v.j. etc ready to go but, IS ALL THAT WATER OUT OF THE NORM???
I drained the oil and ran some cheapo 10-30w through and then drained it before all of this and found a small amount of h20 but nothing like before.
Question: What is the best way to remove that old gasket material without getting it into the block or rings? I sprayed on some gasket remover and scraped for a while with little success. That stuff is the worst I've ever encountered in my life. Wire wheel and plug the holes up with something?? Any ideas here you've used with success?? I'm afraid to get anymore $hit in the block!!
That head was so hard to get off I used a cheater bar and the highlift jack to break it loose from the deck! I'm worried as I need to get this on the road and done due to the weather window closing me out. I'm out of garage space and suck in the driveway. You advice is really appreciated. Thanks Ken
