HELP abs code 51. What do I fix ? (2 Viewers)
avon,nc/courtland,va
abs light is showing code 51 actuator circuit or whatever it says. How do I fix it. The FSm just shows removal
Thanks
So is there simplistic way to swap it out n stuff an have the light off?
Nothing. Cleaned it up got some new sensor wires. Same code. What to do?
My best friend and I both had this code @tromz and we both replaced the ABS pumps and it cured this ABS code. Fairly easy to change. Bleeding is the worst part. I changed the master cylinder while I was in there. $60 for a new Asian MC. Hope this helps.
Jason
The actuator motor you replaced. Or which part. master cylinder has already been replaced
I replaced both pump and master. Didn't have to do the master to get the abs light to go away. Just figured while I had the hard brake lines off it would be another baseline replacement. Rock Auto had a great deal on the Asian brand master.
That pump is expensive. Where did you locate one
Specter wanted like 1000 bucks
Search around. Should be plenty of used ones out there. Part number 44510-60010
Before you change the pump, try jumping it directly using a fused jumper lead.
In most cases, you can tap the power wire quickly on 12v while banging on the pump motor to break it loose.
Once it starts singing, cycle it on and off for a few seconds at a time, then clear the code and you should be good to go.
