I need some help tracking down the problem with my truck. It is an FJ60, but I figured y'all are better troubleshooters in here!
I went on a 3 day trail ride over the New Year's weekend. We went through some pretty deep water the first day - enough to ingest a little and cause a some sputtering. Once that burned off, the truck ran great as usual for the remainder of our time on the trails for the next two days. We did see quite a bit of creek crossings throughout the trip.
On the way home, after some highway driving, I noticed the truck running rough at lower RPMs, but seemed to run fine at speed. I continued the trip home, but the problem seemed to get worse as I went.
With the engine running, I've pulled the plug wires with the engine running to track down the problem cylinders. #3 and #4 don't cause a RPM drop when unplugged.I have replaced the plugs, wires, dizzy cap and rotor with known good parts, and still have the problem. If I hook up an external spark plug, I get a spark from each wire. The spark looks pretty weak, but I have nothing to base that off of.
When I pulled the coil wire off the cap, there was a considerable amount of corrosion on that one connection - so much that I can't see any metal. Could that have toasted the coil / igniter ? Besides some fouled plugs, that is the only visible problem I can find.
Where do I start?
Where do I start?
