Hello all,
I have a 1976 FJ40. A rock recently went through my passenger front roll up window and now I am faced with installing the glass.
(Thankfully) I sourced a used passenger window today with the bottom door glass channel in tact. (this is the channel that attaches the glass to the regulator)
Here is my question. Can the glass be installed without removing the window channel or window felts?
(I briefly attempted to install the glass without removing the felt or the channel and did not want to push my luck.)
If the channels and felt MUST be removed can anyone explain exactly which items need to be removed to successfully insert the glass into the door? (as well as how to remove them) I am asking because I looked online the the replacement felt and channel are $170. (If there is any way I can successfully reuse these part I want to)
If anyone has successfully reused these items please explain how.
Thank you for reading. Any and all help would be greatly appreciated.
Renn in Portland, Oregon
