- Joined
- Nov 5, 2010
- Threads
- 33
- Messages
- 713
- Location
- Southern Iowa
- Website
- www.springtailsolutions.com
Alright, I am sure that many of you can identify with this scenario...I took my doors apart more than a year ago, now I forgot exactly how they go back together. The manual is not much help either.
I put the following instructions together for the sake of saving your sanity when it comes down to remembering the sequence of assembly.
First of all....find a nice sturdy surface to hang the doors on. If they are on your truck, it will probably be all the easier.
The door latch is next, I remembered how hard the stainless bolts were to get out so I made sure to apply some anti-sieze to the threads.
Next in goes the cylinder door lock, I could not find the stock rubber gaskets so I applied a little clear silicone instead.
Should look like this installed
Next...in with the door handle
Inside view
Bolt it up like this...what the picture does not show is that the armature should be swung upwards and bolted to the door
Clean out the old window channel to install the new rubber guides
I lubed the guide with Silicone seal to aid in lubricating the rubber guide.
A brisk push with a very long screwdriver
Now in place
Inside view
Now in place
