This is a new option for GX470 owners to the LRA tank. They did a pre-sale and I was one of the 20. It was 1200 USD+ shipping, cost to go up after this batch.
It’s an aluminum tank with 17 gallons capacity.
First off, packing was okay. I think it needs more internal packing because you can’t count on the couriers to not beat up parcels. But, it’s a heck of a lot lighter than the LRA and can be shipped in a box.
Tank itself looks well made
All parts listed were present.
First thing I worked on was wiring. I lost some of the pictures somehow, but it’s quite simple. There’s a switch that looks like it’s probably the same as LRA. It has a controller box it connects to via a harness. Then you just need power and ground, and then there’s a shielded pair of wires that goes to the tank area. I took power and ground from under the hood at my blue sea fuse block.
Mounting the switch was pretty easy, I used a 3/4 spade bit to punch a hole in one of my 3d printed switch panels and then did final enlarging with a round file. I should have put it about 2mm higher but it’s fine.
I’ll post more as I go. I ordered a used fuel filler neck to do the mods to, that way I can both have a spare if I ever have to reverse it, and I can get help with the welding and be prepared to do the final install in one shot.
