So this is likely just an indicator that I might have some OCD tendencies, but I bought five used RWs and my worldview will not let me use them without taking the rings off, cleaning them up etc. With five wheels, and twelve bolts per ring, I started with 60 bolts to loosen and remove. Penetrating oils, ATF/acetone, heat and beat, etc were all used with some successes, and so far I have had over 30 T-30 torx bits fail...but I still have about 17 bolts to go, and two more with broken off heads. With the two snapped bolt heads I have reached the point where I am looking at other options, with the prevailing idea being to drill out the remaining bolts and reestablish threads with helicoils or Time-serts. However, while I knew they existed, I have no personal experience with them and I have some concerns with ending up with five pounds of weight on a wheel to get it balanced, issues with threads spinning in holes, etc. After scouring the internet, I remembered that the members of this forum are awesome, and most have far more experience than I do, and I figured I would simply ask for opinions on thread inserts as a way to get these wheels back in action? Suggestions for good techniques and lessons learned are certainly welcome too!
