HEi : O-ring or gasket?
Val-David
O.k. After changing the intake on my 1985 305 V8, I got confused by the HEI dizzy. I have a O-ring AND a gasket in my gasket kit, but I only have a gasket on the dizzy. Is it possible that the O-ring is for another model ?
Thanks :beer:
North Bend, WA
The V8 gasket set fits many different years. Mine have all been gaskets (327 & 350) Maybe the newer ones use Orings
Val-David
.which dizzy do you have?
GM HEI on a 305 V8.
i know that on my GM (hei) dizzy, there was an o-ring on the diz shaft.
What year / model is your engine?
If I have the gasket on my dizzy, then it means I don't need the O-ring?
Thanks !!
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
When I installed it on my 2F, the o ring didn't do the job. I made a gsaket amd e-mailed Performance distributors to see what was the correct answer. They sent me a gasket which will sit on the shelf until the next time I take mine out.
As you have a different engine, not sure if this is apllicable.
Ken
Val-David
o.k. now I know I have the gasket style but, how can you know if you get one used or at the junkyard? There must be a way to see it?? If I have a gasket style dizy , can I use a O-ring style dizzy in my engine?
nashville, tn
wish i could help out more....i put a diz out of a 79 nova with a 260 i-6 into my 2F, so i have no clue about v8 stuff...sorry
malphrus
