Just a random thought about an upcomming project. Is it truly required for the throttle body coolant lines to be extended when installing the supercharger? If the coolant is 190* or so it effectively is preheating the intake air for the blower. I have seen this discussion on other vehicles that are not force feed and people are having real results with a make shift, air to water intercooler that cools the throttlebody with seperate coolant from a reservor. Seems like a lot of work, yet on a VR6 transplanted into a beetle that was having pinging problems it made the difference. this perticular vehicle was being flogged in the Vegas area in N/A form.
My thought was to just run the 2 lines together and not heat the throttlebody. There maybe some concerns about the throttle icing up? also what do the folks that are forced run for ignition timing? stock? 3 degrees? or maybe less?
