My alternator died yesterday, and during the replacement I accidentally left off the insulator from the regulator. Didn't notice it until I went to connect the positive power back to the battery, at which point quite a bit of smoke poured out from the wiring I was holding. Disconnected it and fixed the insulator problem, but now my headlights don't work. Driving lights work, as do indicators and brakes etc, but no low or high beams, no spot lights (wired through high beams). I've checked every fuse that I can find in the car not that there are a lot in the old 75 series. Haven't replaced the relays under the bonnet but I did test them and they tested fine. Is there anywhere else someone can think of to look? Is there a hidden relay or fuse in the dash? It's probably auto electrician time but I just want to make sure it's not something easy to fix.
