Headlight flicker
kcjaz
Olathe, KS
My headlights are intermittently flickering. Bulb going bad? What else might cause this?
I have the same issue on my 2014 LC. The battery was going bad, so I thought that was the cause. Replaced the battery and it is still flickering.
Both sides or only one?
It can be the ballast or the bulb. If its only one side, swap the bulb with the other side and check, and if the same bulb is flickering its the bulb that needs changing and if its the same side, youll have to change the ballast too.
I had this before, had to change one ballast and one bulb and now all is well.
It's the bulb. I have to do mine as well, getting very annoying.
This is a good thread:
