Hello everyone, having done a thorough search on this forum, I was looking for a conclusive opinion from you guys on my issue before I proceed any further. I will explain the issue and whats been done already. I suspect HG failure.
'96 LX450 with 188k. The HG was replaced at 155k with new valve seals and coolant flush. Bought it off a fellow mudder when it had 167k, who meticulously maintained it (I can name him if needed, I don't think he is on the forums anymore). I maintain it at regular intervals. He used green Prestone coolant, so I continued as well.
I had to drive from Los Angeles to Yakima, WA last week. Fiance drove the 80, I drove my Dodge. At about 60 miles south of Bend OR, the AC cutoff and she noticed the needle creep up. Stopped at a rest stop and idled for a bit, and the needle went up to the red. Shut off the engine. No coolant in overflow, but had whiffs of the coolant smell. Drove the Dodge to nearest gas station (1 mile away fortunately) and got some coolant. Went back to 80, filled it up, and let it cool. Checked the needle by turning the key, still needle above midpoint. Let it cool for nearly an hour. Then drove the 80 to that gas station and the needle started to creep up again. Stopped, let it cool, and fill up more coolant. Apparently its eating coolant is my first diagnosis. Eventually, after a few starts, slow driving, fill up coolant, I got it to drive at normal temps. We gave it a shot and started driving with intentions to stop every 45 miles to Yakima. We made it to Yakima, but filled up the coolant overflow every 45 miles or less. Needle was at normal temp the whole time.
So at the house we are staying at, I began further diagnosis the next couple of days, started the engine a few times, and searched the heck out of this forum. I find:
1. Chocolate milkshake under the oil cap, some, but not the oil stick
2. Chocolate milkshake now in my coolant overflow tank (it wasn't like that during the drive from Bend)
3. I have not at anytime gotten white smoke, but its also hot up here in Yakima and throughout the drive from Bend
4. I can't really sense the 'sweet' smell from exhaust pipe, but the exhaust gas smells heavier
5. I forgot to check the bubbles test before I dropped it off at the Toyota dealer, stupid me
6. Dealer says leak/pressure test didn't show oil and coolant transferring both ways. I did not trust their analysis and told them to do more tests. I think they were lazy and just told me, "you need a new HG".
7. All the driving done since Bend and to the dealer, the engine drives fine and smooth and quiet, like it has for the last several thousand miles
8. I changed the oil and filter before this trip and topped off the coolant between low and full
9. I cannot find any leakage anywhere, but I did not check the deep areas where leaks have been found and burn off before they accumulate during driving. The PO changed the PHH to the good stuff.
10. Drive to dealer (about 5 miles), no overheating, needle at normal
I don't know what else I can add, but let me know of your thoughts and questions. Is it the HG or a cracked head, or even oil cooler? I will meet with the dealer again, ask for a leakdown test, check for bubbles, etc. I am not really mechanically inclined (or have the time) so research and questions is my best tool.
Thanks in advance.
Oliver
Thanks in advance.
Oliver
