Head Bolt Torque verification
Portland, OR
In the service manual, for the head bolts Toyota specifies...
1st 29 ft lbs
2nd 90 degree turn
3rd 90 degree turn
And to lube threads with engine oil. I was planning on using anti-seize. Has anybody used anti-seize before? Should I not use it? Should I just do what the manual says and only use a little bit of oil on the threads?
I always just spray wd40 on the threads
Use oil. Coat the threads, the washers, and under the bolt head.
As noted, go with what the manual says.
Thanks guys. I did what the manual stated. Got them all torqued down. Boy, that was a workout...
