Hey All -
Currently ditching the 24V switching solenoid using an IBS relay and a 2.7KW starter. The L/H (PS) battery is now starting and the R/H (DS) is now Aux.
Couple of questions for anyone who has done this conversion:
First pic shows a grey case (interior lights ?) and the black case (labeled starter relay) that were attached to the R/H battery +. Dave2000 connected the interior lights to the Aux +. Does the starter relay (black case) need to connect to either battery?
The second pic shows a ring terminal and a grey plug (signal from turning key to crank position). Both were connected to the solenoid and seem to run to the bottom of the main fuse box. The grey plug is now abondoned, but does the ring terminal need to connect to the L/H battery?
Any help much appreciated!
